查看: 36575|回復: 9
mBot Ranger 高速循線範例_
magiccar 發表於 2018-2-13 01:51 | 顯示全部樓層 |閱讀模式
) `; b+ w7 z' T
  1. #include <Arduino.h>* L, e2 ?" Y* m" G; m9 O' |
  2. #include <MeAuriga.h>- @2 v. U+ b9 W. u$ M" d
  3. #include "MeLineFollowerArray.h"
    , D$ R/ A& ~% [3 |0 C
  4. 1 Y1 Y$ g. n& W2 h4 f* O
  5. MeEncoderOnBoard Encoder_1(SLOT1);
    , p$ W6 \: O- c+ x/ N# q" S
  6. MeEncoderOnBoard Encoder_2(SLOT2);$ ~* u1 P6 G$ T/ V. S3 j1 A6 F% P
  7. MeLightSensor lightsensor_1(12);  d) u; ]! a# N/ Z  k8 \3 j" Y
  8. MeLightSensor lightsensor_2(11);2 a, t* j3 {6 S# K
  9. MeBuzzer buzzer;( L; j2 W8 ]$ W  I
  10. MeLineFollowerArray linefollower(PORT_6);
    % V" ^1 R8 I& ^/ b
  11. , S1 A& I+ P7 @
  12. #define Error1 1
    & k/ |4 m# h4 X' f, k7 M" J" c
  13. #define Error2 22 p+ x" @$ r3 Z/ f
  14. #define Error3 3
    0 |1 ^3 P( ~# }' J  ^
  15. ! h3 d: k5 s! w4 g+ v* }2 J$ _
  16. #define Kp 15* [6 F6 n& z% E# y
  17. #define Ki 0.155 h% Z, _; I3 K
  18. #define Kd 0.03* J7 Q3 j5 \8 Y
  19. % Q1 q3 z3 `$ e2 F
  20. uint8_t sData;3 f( e1 N  l5 ^0 N8 n
  21. uint8_t D1;4 ]" \% w  B; l6 k( k0 q# {- X& {
  22. uint8_t D2;5 O  n  l, X, r
  23. uint8_t D3;
    ' A' y* ^9 z. L/ b
  24. uint8_t D4;
    + @8 R# D" C; [  o" @
  25. uint8_t D5;
    2 `& R. o+ g6 C9 y4 [9 ]4 d0 H
  26. uint8_t D6;
    ' z* {' X0 S4 G+ M! }+ D+ X6 P
  27. 0 G. K: F6 O6 V! E4 d: B
  28. float previous_error = 0;
    0 X9 N) u! X6 s- j. X4 P
  29. float integral = 0;
    / E: v5 X' x* b( [  ^3 u2 k
  30. float derivative = 0;
    1 v  w  Q" Z. B4 T
  31. int  Speed  = 160;
    + ]! ]2 F" z' G! y! c
  32. float output;
    9 d* m! L' h% |
  33. . j& Z: u% H( U' r5 w$ G# C( z& N( k
  34. byte Left;$ ~1 \' Q& j7 c' c' u7 y
  35.   v( T  Z1 h: n. L8 n: K3 ?' H1 \
  36. void setup()
    1 e) T0 G1 S5 g0 a
  37. {
    # E/ s' U- }3 N+ z8 D
  38. //Set PWM 8KHz# K# @2 K! t; h% F& Y4 D, t
  39.   TCCR1A = _BV(WGM10);& M' `  A& p' |- m, X
  40.   TCCR1B = _BV(CS11) | _BV(WGM12);, N; v0 G8 y, z" @' B
  41.   TCCR2A = _BV(WGM21) | _BV(WGM20);
    . E. [) A# `2 Q! ^# D
  42.   TCCR2B = _BV(CS21);: u0 g  P4 z2 _1 q' m+ |1 l
  43.   Serial.begin(9600);+ }+ x* I4 z; F5 i5 j1 j5 l
  44.   buzzer.setpin(45);
    % y+ Z$ L# ~- ^; H
  45. }- X3 e" d0 c- }; ?/ v
  46. $ M' W) U# b  P+ W: j# P2 c
  47. void loop()- Q* V7 [9 u6 O8 i) |" Z. t
  48. {
    ! }& e0 N) J* k# {
  49.   while(!((lightsensor_1.read()) < (10)));# v8 v4 s0 x( j: B, x
  50.   buzzer.tone(1047, 500);9 k6 b% O: G, ^% X5 [/ U: ?
  51.   delay(500);/ f8 U) o+ ~" n. z6 l) h
  52.   do. n$ }# K) k7 \" g) M9 l3 ]: c
  53.   {
    ! n- l5 X% I" L. S! L
  54.    int Err = getErr();
    1 N9 w% T6 u( w( H
  55.    if(D1 == 1)  n! l' N+ P, p
  56.    {3 {. I( _: C' p) W( E
  57.      Left = 1;
    3 G1 L5 b0 u5 t' F, Z
  58.    }
    ( u/ V3 i2 t" _+ W& n
  59.    if(D6 == 1)" d( f& t% w- R7 G5 v; ?* `
  60.    {
    . F% {$ T+ N, u# w
  61.      Left = 0;
    / ~4 l( p8 T  Y1 w* D, a' z
  62.    }& e3 _$ `: ?- p/ j. P* s/ @" x/ `
  63.    if(Err == 99)4 A/ v6 i# J( _. x
  64.    {' @1 m# l/ h0 J/ l  }' a2 \- @3 H
  65.      if(Left == 1)1 y: o8 @- @6 X, L
  66.      {3 T6 W$ \. p2 ^8 S0 I7 c, w0 P: K
  67.        Speed -= 5;
    9 p4 \( Y6 K0 U- Z- v5 L- J
  68.        moto(0,Speed);
      e3 ^/ W$ b. Y
  69.        do
    " l2 D% k& a2 x  F
  70.        {
    ( {8 ]  ^6 A& R* {' u2 y/ A
  71.          Err = getErr();
    3 X- S# D4 K1 v! p6 [9 y* h' m
  72.        }while((D1+D6) == 0);; |0 h; w- p+ x
  73.      }
    . P: ?5 i0 t8 W# R3 t% `
  74.      else7 u  N7 _- C5 i! }
  75.      {
    ; d# |2 B. z  s. H6 n) L
  76.        Speed -= 5;
    * x8 k5 H- I! D
  77.        moto(Speed,0);
    + D. F& _5 J5 E- i
  78.        do$ \' A( @5 o" ]2 x. o3 P6 T
  79.        {! _1 K& u. Y1 m2 u  I
  80.          Err = getErr();' Q) I* X5 y# i# k
  81.        }while((D1+D6) == 0);
    # [( e, \3 n0 V% V
  82.      }
    9 c; r# D* t/ }" S- ?9 \8 S5 g
  83.    }
    : w5 p% l6 Y' E8 M
  84.    else' J& e- Y1 i  C( W
  85.    {
    2 O; I; f& n! ~4 F" I  S8 {% Q9 d
  86.      if((Speed < 160) & (Err < 2)) Speed+=1;
    $ \2 h9 ]% v. b0 J
  87.      if((Speed > 100) & (Err > 2)) Speed-=2;
    , q5 }  g4 G& S. _
  88.      integral = integral + Err;
    & I' C- H' j" T; \$ o
  89.      derivative = Err - previous_error;4 v5 C4 \$ v% y8 i: V2 a* _
  90.      output = Kp*Err + Ki*integral + Kd*derivative;
    * B# H, u( c1 h3 f; \6 a
  91.      moto(int(Speed-output),int(Speed+output));$ @2 n" P5 @+ M7 u
  92.      previous_error = Err;
    . x! O( l) K! A$ ^$ |1 a, @
  93.    }
    3 A. D  B0 I: g, y  R
  94.   }while(!((lightsensor_2.read()) < (10)));, b2 A) }  Q% k' o! q( ]* d6 C3 w
  95.   moto(0,0);
    5 x9 h( g7 V" i1 i0 V- ?4 a
  96.   delay(500);
    - c6 B1 o! U( r+ d7 Q7 x  D! v* d
  97.   buzzer.tone(262, 500);; u" J, Y- P8 R. H+ g
  98. }
    ( {8 P! Q! s8 q9 {3 E( ~8 [
  99. + x7 ]2 C  {) Z& w9 }# u5 n
  100. int getErr()
    7 A7 C& F# l! m5 z: X' F& u
  101. {  $ e3 h5 G' I) q- o
  102.    sData = linefollower.getValue();' U# }: G- ~" w* k
  103.    D1 = ~(sData>>0)&1;, u$ @2 s7 A4 H$ G1 z6 ]
  104.    D2 = ~(sData>>1)&1;7 u( M: `1 J% m2 x: ]
  105.    D3 = ~(sData>>2)&1;: Q: a% r! g" j% T  x- _3 d
  106.    D4 = ~(sData>>3)&1;" ^% p( V- ?1 J5 `
  107.    D5 = ~(sData>>4)&1;
    . [  Z0 G2 Z; x: `( _
  108.    D6 = ~(sData>>5)&1;# V, _( k$ I, Z+ v0 f
  109.    int downD = D1+D2+D3+D4+D5+D6;
    ) H2 Y0 I& s$ S$ g# V* M, a. l7 J0 Y
  110.    int upD = D1*(Error3)+D2*(Error2)+D3*(Error1)+D4*(-Error1)+D5*(-Error2)+D6*(-Error3);
    9 a& O. }* `$ f1 {2 K% O
  111.    if(downD == 0)
    9 N; P4 B, f+ z; q
  112.    {- w- e6 K3 R9 S5 `
  113.      return 99;3 F9 Z- J" Y) k; ]
  114.    }* _& g9 d  o  w2 J& h
  115.    else8 n: {+ ]5 I  q2 V$ V! _
  116.    {7 i) T$ A  s, `9 Q6 [
  117.     return upD/downD;1 W+ H  \; Z$ v% m! ^  b" f$ u
  118.    }
    : T; f7 T8 d+ ^1 ?" Y! n
  119. }7 B. i" N# j# s% b; f5 `( _
  120. : _8 g" I4 R6 x' m9 J) U; i( C
  121. void moto(int Speed_L,int Speed_R)
    - w1 a0 U+ [8 k# D
  122. {
    6 [# u. u: r  u8 y% Z# t
  123.   Encoder_2.setMotorPwm(Speed_L);8 z% J3 D- h  j9 ~9 S5 T# Y- |
  124.   Encoder_1.setMotorPwm(-Speed_R);/ ]. c& y  s, [! a
  125. }
: p( l) w! z- p+ X8 JMeLineFollowerArray.cpp/ n7 L8 ~& ]0 W. A' S
  1. #include "MeLineFollowerArray.h"( e+ r; K. }3 X3 r) U) A
  2. % Y- O, \7 \$ J& K' _7 W0 [
  3. #ifdef ME_PORT_DEFINED
    * D& a1 n9 j4 f
  4. MeLineFollowerArray::MeLineFollowerArray(void) : MePort(0)
    / U' P/ j3 g" _" ~# Y; m  i7 c- J
  5. {
    ( O7 o& g! [6 ^  O( _
  6. 2 F/ w: K; @4 F. S8 L! q* I
  7. }
      Y1 M! Y0 o9 A! m+ z3 e1 S
  8. MeLineFollowerArray::MeLineFollowerArray(uint8_t port) : MePort(port)* ?& s) B' J+ M% O- o! P  ^5 X
  9. {2 i. j0 U4 O- e; Q& O; b6 {
  10.     _DataPin = mePort[port].s2;$ O5 l$ p. P" W( A# K0 ?
  11.     pinMode(_DataPin, OUTPUT);
    6 i$ l3 E! J2 G% \5 A
  12.     digitalWrite(_DataPin, HIGH);( L3 a  r$ T0 I  U, ~+ M
  13. }
    # `, {  {# h  @) p
  14. #else // ME_PORT_DEFINED
    * @5 W9 a5 H( {7 W
  15. MeLineFollowerArray::MeLineFollowerArray(uint8_t pin)
    1 M: J0 K4 U' Q3 D( ]! {
  16. {. l& h1 }" ]- l6 P1 @, w# _* _5 X
  17.     _DataPin = pin;
    8 r/ j6 e( v! G% F
  18.     pinMode(_DataPin, OUTPUT);
    0 C7 V0 D3 n& ~+ |  |6 I! c9 [
  19.     digitalWrite(_DataPin, HIGH);
    2 V6 y& E8 G  y# X6 p/ f
  20. }$ ^" b1 {$ f9 o; C
  21. #endif // ME_PORT_DEFINED/ _2 q+ _0 h# h' _2 ^# Q
  22. ! u5 I. h( r) {" l9 s. R
  23. 7 l8 l/ Z$ h# u9 K: W' g
  24. void MeLineFollowerArray::setpin(uint8_t pin)' a: E* J6 y, k- n
  25. {
    ; g2 y4 M. b, J0 k* U: S
  26.     _DataPin = pin;
    6 ?, f! T/ k8 t7 }
  27.     pinMode(_DataPin, OUTPUT); 0 q, R! L4 s8 a% z% A. R
  28.     digitalWrite(_DataPin, HIGH);
    5 `; A/ s; ]% ^% m+ I3 P7 |
  29. 8 b# @9 D. e. x8 t2 @
  30.     #ifdef ME_PORT_DEFINED( ?2 C0 g% F9 ~. M( {
  31.     s2 = pin;/ a/ d0 ?6 B$ H6 G
  32.     #endif
    3 t3 i. |5 p/ S5 G
  33. }
    / R0 S0 }8 W- w3 y9 g4 A
  34. 9 O, r8 ]& F8 Y5 }' u
  35. uint8_t MeLineFollowerArray::getValue()& A! o/ q5 g( |1 O. k
  36. {$ k. j& o3 F) }2 W; k5 P! b& @4 ?
  37.     uint32_t LOW_level_read_time;8 ?, j* f$ l( M2 T
  38.     uint32_t HIGH_level_read_time;
    / x( T5 Q  ]9 i+ B
  39.     uint32_t time_out_flag;
      p, @6 N! ?; {- F
  40.     uint8_t Sensor_Data[3];  k: E9 W& |) [+ i9 x, w8 L( M
  41.     static uint8_t old_data = 0xff;
    4 T! X$ T: Q) u' e! B0 ~
  42. 3 d/ A1 _( L! e/ n1 `/ }
  43.     pinMode(_DataPin, OUTPUT);
    " ]: s/ Y5 c0 c5 U2 }
  44.     digitalWrite(_DataPin, LOW);
    4 \8 C8 ~5 r5 D- A! ~
  45.     delayMicroseconds(980);
    " ]8 y" I* Z4 D5 M# H- z4 o8 U
  46.     digitalWrite(_DataPin, HIGH);, G" h4 _* e4 e
  47. & u5 W2 x( f" Q
  48.     pinMode(_DataPin, INPUT_PULLUP);# v* I* ~/ C# o+ Z, J& V. |* X
  49.     delayMicroseconds(10);
    1 r& I1 d8 o9 M
  50. * ?3 l6 Z! }; m3 }2 a9 W0 _8 C
  51.     time_out_flag = millis();1 V1 [) y/ o, u# l, Z  W5 f
  52.     while(digitalRead(_DataPin) == 1 && ((millis() - time_out_flag) < MeLineFollowerArray_Communication_Time_Out) );
    8 F! I8 x3 A  H/ V5 ?3 H# {/ q
  53. : N4 X) J2 W1 L6 k
  54.     LOW_level_read_time = micros();
    / E7 ]- d) }4 k3 B4 S
  55.     if((millis() - time_out_flag) >= MeLineFollowerArray_Communication_Time_Out)   //time out
    6 L& I4 e) p. D2 S$ j# ^8 Z, k
  56.     {
    ' O$ s* f( [* X. s$ q: e2 h$ K% ~
  57.         return 0xff;
    . i1 a* q# E$ M
  58.     }
    3 s) L4 Y0 x- ~9 b6 G8 |0 \: R
  59. 1 F; t: B% J9 `4 f  `( B9 y
  60.     while(digitalRead(_DataPin) == 0 && ((millis() - time_out_flag) < MeLineFollowerArray_Communication_Time_Out) );% B) _/ _1 ^% q
  61. ; b2 S: f8 H7 ~- u# q
  62.     HIGH_level_read_time = micros();
    / E7 W9 }8 p0 L. |! K
  63.     LOW_level_read_time  = micros() - LOW_level_read_time;    //read 100us LOW level
    4 m0 f4 E( n  p  _3 f( l( I
  64. & ?+ }3 t6 `) R2 U
  65.     if((millis() - time_out_flag) >= MeLineFollowerArray_Communication_Time_Out)   //time out2 @9 J+ h( {4 K5 {
  66.     {
    4 d8 X; q% y3 [" G% N- f
  67.         return 0xff;
    ! d0 u# p& c0 [/ @. |9 h; O
  68.     }1 s" T* L' E3 z+ b4 Y5 [
  69. % Z( C; p$ P1 u
  70.     if( (LOW_level_read_time < 90) && (LOW_level_read_time > 110))5 P& M- @; u  m* @2 d, U
  71.     {
    ! a# e* u1 g% t$ O) H% f
  72.         return 0xff;% ?; l* q5 [0 \+ C1 m( ]
  73.     }2 x& I. r2 u, p4 Z( l9 X/ g
  74. . ]0 C7 z' ~9 W
  75.     while(digitalRead(_DataPin) == 1 && ((millis() - time_out_flag) < MeLineFollowerArray_Communication_Time_Out) );0 V3 S: ^, ]" b+ u: X
  76.     LOW_level_read_time  = micros();
    : B% q  H4 r# l* F9 }" l& }7 w
  77.     HIGH_level_read_time = micros() - HIGH_level_read_time;    //read 50us HIGH level$ k2 g. u! f& ]' F- B/ ^/ m
  78. % G$ D3 u+ E' Q
  79.     if((millis() - time_out_flag) >= MeLineFollowerArray_Communication_Time_Out)   //time out' p) a1 x  `( Z9 t4 E/ S
  80.     {  i5 B+ V: d# Q4 `) P$ R) f
  81.         return 0xff;. I) |- `" g1 d/ T
  82.     }- }, g  v# m! z$ T3 j; h( k
  83. % N; J8 N0 v! @; W3 T" ?
  84.     if( (HIGH_level_read_time < 5) && (HIGH_level_read_time > 55))3 _5 f) m( H% Z$ u& k
  85.     {9 e( W6 p5 W: a/ _: E' S8 N! N2 g+ ^
  86.         return 0xff;
    ) C! a) C+ F! @( |3 z  b
  87.     }
    ! d& e( i, K- v2 L) O, q' }7 }& Y
  88. - e+ e7 `4 @! t3 U1 g
  89.     for(uint8_t k=0; k<3; k++)( V( g' U( l( z$ Z- ?" J
  90.     {* U# Z+ M. X( W/ R
  91.         Sensor_Data[k] = 0x00;
    ) q- R- r0 ]! D2 X6 Y
  92. ; ]( m+ E* L1 k, z
  93.         for(uint8_t i=0;i<8;i++)0 b3 |& L; X8 R9 q
  94.         {
    $ K' E$ ]/ p9 R, P' ]3 U  U, @6 F
  95.             while(digitalRead(_DataPin) == 0 && ((millis() - time_out_flag) < MeLineFollowerArray_Communication_Time_Out) );   //read 50us LOW level
      g* n) x" J! i  O& C) G
  96.             HIGH_level_read_time = micros();' ]) c$ e0 \; }8 a
  97.             LOW_level_read_time  = micros() - LOW_level_read_time;8 e' b! ~0 s; r! T; s, s  G
  98. # {2 ^1 G$ j$ {* I3 \
  99.             if( (LOW_level_read_time < 5) && (LOW_level_read_time > 55) )$ d5 ~/ `- [0 W! \
  100.             {& A1 ~6 C, v1 D' I& ~
  101.                 return 0xff;
    ' d* r7 B6 Q: k, P% c' }& r+ U% ]
  102.             }
    , H- Y8 q& ?% n* J& |
  103. # t5 u" `8 n' O, n
  104.             while(digitalRead(_DataPin) == 1 && ((millis() - time_out_flag) < MeLineFollowerArray_Communication_Time_Out) );6 ]# s4 D& m# m) ^( k9 T1 j
  105.             LOW_level_read_time  = micros();# n, z3 D+ j) ]& H
  106.             HIGH_level_read_time = micros() - HIGH_level_read_time;    //read HIGH level- o* [1 c# l2 E! P- D  m1 t
  107. 3 o) H2 W% r- L4 b
  108.             if(HIGH_level_read_time > 50 && HIGH_level_read_time < 100)   //bit 1
    , K3 \7 V, |- K( i$ |
  109.             {
    % h- C2 O; R4 P  h
  110.                 Sensor_Data[k] |= (0x80 >> i);  ~- t, x( Q: \+ r) u! _
  111.             }
    ' b. X: ]+ c* i" }5 |+ T3 z
  112.             else if(HIGH_level_read_time >= 100)8 x& J/ P9 f* F
  113.             {1 [/ a9 _9 j8 b) o0 q% g
  114.                 return 0xff;
    1 z, {/ t" c# l4 j6 \# k5 e
  115.             }9 l6 D/ s2 ], x' c0 ~0 K$ U/ j
  116. ( ]2 _6 I% U  Q6 Q
  117.             if((millis() - time_out_flag) >= MeLineFollowerArray_Communication_Time_Out)
    2 u2 q9 `- [$ I8 O% U( O
  118.             {
    1 P$ M0 C! o0 a  a
  119.                 return 0xff;
    7 ^: i- B5 ^. q; F6 ^3 Q- k( d
  120.             }4 o8 P0 t2 d% o( i. x
  121.         }
    / ^& r5 Q* n+ g9 r# Y
  122.     }
    ) j. Z1 ^) U. V, K4 M
  123. 0 M. a. o6 |' g3 J$ t+ _
  124.     while(digitalRead(_DataPin) == 0 && ((millis() - time_out_flag) < MeLineFollowerArray_Communication_Time_Out) );   //read 50us LOW level+ C' \  v0 }2 b" ~, ]7 {
  125.     HIGH_level_read_time = micros();
    ; `  ]: y+ ]3 a$ }' Y; V) h. M; t4 }
  126.     LOW_level_read_time  = micros() - LOW_level_read_time;
    ; n1 P+ O& s9 T, ~" T; |
  127. 5 k" L9 `2 P" o  S3 J9 c+ a. \$ l
  128.     if( (LOW_level_read_time < 5) && (LOW_level_read_time > 55) )2 G4 _6 H4 V4 p7 u
  129.     {! H/ @% I- r& W9 i" v
  130.         return 0xff;4 O$ ~( n/ f  g* K+ W' o
  131.     }% J# F' v/ h  d
  132. " a5 `! k- i- \. s
  133.     pinMode(_DataPin, OUTPUT);
    " b; v; ~+ w4 i5 n( i% i( k, N
  134.     digitalWrite(_DataPin, HIGH);
    $ ^3 R* R$ v  d' U4 j
  135. 7 T7 Q# _4 b7 g4 I& S3 H
  136.     if( (Sensor_Data[2] == (uint8_t)(Sensor_Data[1] - Sensor_Data[0])) && (Sensor_Data[1] == (uint8_t)(~(uint8_t)Sensor_Data[0])))  p3 E+ m" @9 I7 ^# ^3 M  ^" w
  137.     {3 X8 |3 |1 r8 L  r- G$ x! t, J
  138.         old_data = Sensor_Data[0];
    $ W+ x; g% Z2 \% y- c) @
  139.         return Sensor_Data[0];
    , f7 }$ `3 U$ q. h4 t
  140.     }
      E, a# ~( J# n! O, a
  141.     else/ o$ `# S8 w! P
  142.     {
    ; b. H4 }$ G8 l3 n7 N
  143.         return old_data;& R1 g' D! m) y2 t! E
  144.     }+ J0 O/ U. v8 D! [1 ?
  145. }# }0 \4 `9 u) x9 Q, W% N( H$ ]( |7 j
" p' [1 O! O3 y6 M' T9 QMeLineFollowerArray.h   MeLineFollowerArray.h (731 Bytes, 下載次數: 10, 售價: 100 個銅錢) / \% S$ p% ]& U, P) u0 Z  r/ K. h
- F* B7 z% y. M* k9 K
bw2014 發表於 2019-6-29 00:03 | 顯示全部樓層
強力推廣中
daven 發表於 2019-3-6 00:09 | 顯示全部樓層
哇...要100 個銅錢
 樓主| magiccar 發表於 2019-3-6 00:16 | 顯示全部樓層
  A$ D9 N1 p! v8 n) C6 O7 Z% X$ K哇...要100 個銅錢
* L5 p$ v/ i. ]* W# x$ O6 Y$ E1 `
認真的回饋本站一些內容, 很容易達成的!
delphi 發表於 2019-3-26 14:19 | 顯示全部樓層
感謝分享,還不夠權限下載
gary0317 發表於 2019-5-20 19:15 | 顯示全部樓層
感謝分享Thanks
roboger 發表於 2020-11-13 15:43 | 顯示全部樓層
能否用到mblock 5 上面呢?
 樓主| magiccar 發表於 2020-11-25 08:53 | 顯示全部樓層
) j/ y0 |) i. T6 `$ }' b' Q能否用到mblock 5 上面呢?
6 O. G4 J2 V3 R  j3 O/ I
MeLineFollowerArray 在 mBlock5 中, 只有支援 megaPi 控制板, Ranger 無法使用, 如有需求, 我再寫一個擴展上架吧!
roboger 發表於 2020-12-10 15:09 | 顯示全部樓層
无法添加到扩展呀
ksvsn009 發表於 2021-3-16 23:23 | 顯示全部樓層
高手就是高手
GMT+8, 2025-12-6 11:50 , Processed in 0.033699 second(s), 21 queries .
